Welcome to Vend Resource's Forums - Getting Started
Last seen: 1 week 1 day ago
Hello,
Hope you like our forums and find them helpful. Our users will attempt to help you diagnose what's wrong with your machine and help you fix it.
As visitor you may view(read) any topic on the board.
You will need to register in order to post a 'newtopic' (ask a question/describe a problem). It's easy and it's FREE!
In the lower lefthand corner of any webpage find the 'USER LOGIN' block, click on create 'CREATE NEW ACCOUNT' link, username and email are required, other info is optional, follow instructions and thats it! You're all set!
Before you Post:
Check the already posted 'topics' and replies to see if the answer is there.
If you don't find an answer there, Click on 'Post new topic'. State your problem as clearly as possible, and check back in a few days and see if someone has replied.
Please select the appropriate forum from the drop down list for your new question, i.e. If it is a repair question it goes in "Vending Repair Forum", etc. If you put it the wrong forum, we will move to the correct forum, but you will then have a hard time finding it when you come back.
Please Use a Descriptive Title.
This is simple; help us to help you. When you create your thread / post, think of it as if someone else is reading it. With that in mind, make your subject lines related to the content of your post. Having a subject line of 'help' or 'now what', will not really help others later when they do a search for a particular issue, but a subject like 'compressor problem' or 'coin mech not accepting coin' is much better. So, try to be helpful.
Avatars, User Names, Signatures, General Posting Guidelines.
Member User Names and Avatars must be appropriate for a Public Forum of all ages. If the moderation team does not feel your Avatar or User Name is appropriate you will kindly be asked to change it (User Name will be changed to one of your choosing by Administration).
Signatures may contain images, but may not be too large. If your signature is larger than that deemed acceptable by staff, you will be requested by a moderator to resize or change your image. Signatures may contain up to one external website link (points to a webpage outside of Vending-LA.com/Vend Forums) and one email link. Also keep signatures under a total of 4 lines. Failing to comply with a moderator's request will result in the removal of your signature.
In the "Introduce Yourself" Forum you may describe yourself and your business, including images(5) and web links to your website provided it is vending related.
THE RULES:
There will be no excessive use of profanity.
There will be no racial, ethnic, gender based insults or any other personal discriminations.
There will be no posts meant to offend or hurt any other member, in a manner which is offensive or inflammatory.
Spamming is not permitted at all IF it is non-vending related. If your post or reply is helpful to the vending topic being discussed you may post "helpful links" to other websites. Please keep all your posts as constructive as possible. If the administrator deems your post to be total spam it will be deleted.
Pornography, warez, or any other illegal transactions may NOT be linked in any shape or form.
All posts are property of the poster. This forum and all web sites owned in conjunction with this forum have the right to request alteration or deletion of any offensive post. Posts may be deleted for any reasons the forum administrators deem reasonable.
Any and all complaints directed at a moderator should first address the moderator in question via Email. If the problem can not be resolved, then the moderator and user must send their positions to the forum admin. The forum admin will make or change any and/or all final decisions.
Pictures and images may be posted as long as they are not explicit or offensive.
We reserve the right to remove any topics we deem inappropriate or disruptive to our community. Please note that, from time to time, topics may be removed for being inappropriate even though your individual post in that topic may have been perfectly fine. Please do not feel this reflects badly on you.
Thanks,
fdg123, administrator
Edited by: fdg123 on 07/09/2019 - 21:10
