AP Snackshop 6000 snack machine not working
rpmaddox2000
Last seen: 12 years 11 months ago
I'm having a problem with my Automated Products Snackshop 6000 snack vending machine. It will accept coins but when any slot is entered (e.g., A1), the "make other selection" light blinks and nothing vends. Then, when I open the machine and switch it to "Test Vend" mode and start entering slots to test, nothing turns for any slot I enter--not even the gum slots.
I took out all the shelves and traced the wires to the control board to see if any wires were unplugged, but unfortunately everything was plugged in. There does not appear to be an electrical issue because I can dispense coins and change prices with no problem. Any ideas?
Edited by: rpmaddox2000 on 02/12/2012 - 18:23
AP 6000 Controller Board problem.
rpmadddox2000,
Couple of things come to mind;
1. Your controller board's battery may be dead. So that when there is a power glitch (from a short in the line OR the machine) you lose all your prices. Try putting new prices on every selection and then purchase an item from a selection. Make sure there is no power "glich" while you are doing this.
2. If this doesn't work then you may have controller board bad in the section that the controls motors.
If you need more help post again, I will try my best,
