bubble coke cola machine not accepting money
washanddry361
Last seen: 9 years 9 months ago
just purchased a coke machine get it back to my shop turn it on and throw the quarters in then all the money falls through the coin mec and out to the coin return slot. it will never hold the change? the cash acceptor was already broken but it would hold the change before I purchased it. as for the prices I have the fifth and third switch push in which I believe is 80 cents and 20 cents.
1
2
3
4
5
6
7
8
then there are two more buttons below that, that read on and off and they are both pointed to off.
any help is greatly appreciated
washanddry361
help
help
First of all you need to post the model number of your machine
and tell us what logic board is in it so we know what you have. The model number should be on the left outside edge of the door. If that plate is missing then it could be written on the inner insulated door or on the back of the machine. If it's not there either then you can post a photo of it inside and out. If you know the model of the logic board that could also be enough for us to help you.
