Dixie Narco 276 dumping Product
rbunkley
Last seen: 10 years 7 months ago
Dixie Narco 276. Multi price soda machine. When a selection is made sometimes the machine will dump everything in that selection. I'm new to vending. What's going on with this machine?
Edited by: rbunkley on 02/20/2014 - 14:22
Last seen: 1 month 2 weeks ago
Soda Machine dispensing multiple cans at a time.
rbunkley,
Sounds like your machine is 'jack-potting', this is usually caused by a sticky brake. This is usually caused by soda spills building up over time. You need to clean it with a solution of ammonia and water.
First Unplug the machine! In the picture below the red arrow is pointing down to the brake (it is the metal lever) clean this and it's hinge and also clean the little white plastic catch on the other hinge post. After everything dries out, plug back in the machine and it should work correctly.
Frank
rbunkley
DN Dumping
I can see the brake on your pic. Can you tell me where the brake is on mine?
Location of vend motor brake dixie-narco 276
rbunkley,
in the picture below I added a red arrow to your picture pointing to the brake. On your machine both the metal and plastic parts are on the same hinge post. Be sure to clean both pieces and the hinge post until they move freely.
dixie narco 276 vend motor and brake
