DN not vending when I press the button
Travis
Last seen: 4 years 8 months ago
I just purchased a Dixie Narco 368m/216-8 PE2358 and do not know much about it. When I plug it in it lights up and accepts coins like it is supposed to. The cams are all in the home position but when I put the money in it will not dispense any soda. I have filled the bins with 8 cans and the lights go off but will not dispense. If I press the small lever on the cam it will work but not with the button on the front of the machine. Any advice would be greatly appreciated.
Selection Button not Working
Travis,
Couple of things I can think of, first if it is happenning on all buttons, I would check the vend solenoid/relay. Swap in a known good one, or new one, they are cheap and just plug in. A hood vending parts supplier can tell you the solenoid you need from your make/model#.
Second, check for loose or disconnected wires on a button switch, and if all wires are good swap in a known good or new button switch. They're cheap also.
