Hello, I'm the latest newbie here, just joined.
I'm not sure the make and or model of this machine, any help is greatly appreciated. Also, any information on where I might be able to download a manual would be great! I'm trying to fix it, it wont take money, bill acceptor doesn't seem to work and coins just go strait to the change dispenser.
Thanks.
BUMP.....
-Dave
dbpbandit,
Your pictures are such low resolution it is hard to tell much. From your first picture it looks like it might be a Dixie-Narco.
It would greatly help if you uploaded better pictures, this forum accepts much larger pictures for upload.
If you can't get better pictures, try reading this post in our forum here: Identiyfing the make and model of your soda machine.
It will tell you where to look for id plate, embossed manufacturers name, etc. And after you figure out the make(the manufacturer) then you can use dimensions to narrow down the model number.
Once you know the make and model number we have the service manual for most machines in our library section.
As for that controller board it does not look like any I have seen on a soda machine. Sorry.
hope this helps,
