Lance Vending Machine repair problem
Bzerbel
Last seen: 5 years 4 months ago
I have an old Lance Vending machine. (no DBA) 15 selections. Last week the number 13 selection got jammed. Now neither it nor 15 will vend. Already tested both motors and they work. I'm assuming both switches work as when I move the coils the switch engages and the motor turns then stops at designated place. What else should I look at?
Old Snack Machine Not Vending
Bzerbel,
I used to own an old Lance machine. They are made by USI/Fawn. Most of thisevold snack machines were wired in series, so if one selection had a problem it messed up selections after that. I would first test the microswitch by swapping in a good one. Otherwise it sounds like could be short or loose wire & you will just have to track it down.
The RS
