Machine wont turn off and is freezing and exploding sodas
allstarmusic
Last seen: 14 years 5 months ago
I have what I belive is a Dixie Narco witht the thermostat in the front right. The machine was bought used and has worked great for 2 years. It nor will not turn off and is freezing and exploding all the sodas. Any suggestions?
Anthony
Anthony, You need to
Anthony,
You need to replace The thermostat. Its not hard but finding the right one may be. If you have a vending parts
company or sometimes the a local bottler will sell you an OEM t-stat. IF you can't find and have an appliance parts store I can give you some aftermarket #'s. Beware of taking your t-stat with you and asking for replacement you may or may not get what you need. Aftermarket part #'s with 505 or 506 will work. 505 need to be mounted secondary air 506 primary air as in OEM part. Beaware that the Supco t-stats are not holding up to amp rating I've had to warranty about 75 t-stat replacements in the last year.
Steve
