Hi I wonder if someone can help me pls. I have a Manea Vending machine and recently its stopped cooling the drinks in the machine. There was large chunks of ice on the compressor at the bottom of the machine which I defrosted overnight but the ice returned when turning the machine back on. I called an engineer to look at it and he said the fan had stopped working completely but also the power board that the compressor was connected to was also not working, making the compressor hot. The power board as seen in the picture has a ref ENO458rev0. I don't know where to get this part or the fan and not even sure if the information i have been told is correct as he was a fridge repairman and not a vending expert. Some help in this matter will be greatly appreciated. Thank you Mike :)
Attachment | Size |
![]() | 1.88 MB |
Mikey Mikes Vending,
I have never worked on or seen a Manea Vending Machine, but replacing a fan motor is usually fairly easy and cheap. When a machine I am familiar with freezes up with ice that is what I recommend that a person try first (replace the fan motor). A fan motor is also usually a lot cheaper to buy than a controller board. If you need to order parts Manea Vending's contact info is listed in our Vending Directory here: http://www.vend-resource.com/vending-directory/manea-vending
