Numerous problems with DNCB 240 /138-5
Parrt2009
Last seen: 8 years 11 months ago
Mid 80s style COKE machine, bigger 1&2 button recently started tripping my GFI outlet in my garage. Two smaller selectors below do not click like the others do. Flap at the bottowm, i think is called a shiv? Doesn't want to spit out my 12oz Coronas like i want it to. I put in correct change and it spits out nickles and dimes? Also looking for replacement logos but searching the internet seems scare on parts or anything for that matter so thought I'd try here. Thank you for your help in advance.
You probably have a bad sequencing relay
that switches between columns 1 and 2 and which also is activated by your odd or even only buttons. I don't know what you mean by the shiv at the bottom that won't vend you Corona but are you speaking of the rotor that turns in the column? If you'll email me at rbepic4gatgmaildotcom I can send you a new sequencing solenoid and any other parts you might need.
