v193 vend moter sticking
gumdrop
Last seen: 10 years 12 months ago
My v193 moter is sticking .It drops 2 cans and then none . What can I do?
Recheck your model number
gumdrop,
I will assume you are referring to a Vendo? Model# 193?
Please recheck your model number because I have never heard of a Model 193 by Vendo.
If you can't find the model number, is your machine a 2 can or 3 can deep machine? You can tell by whether you can fit 3 cans deep in a selection column or not.
I think I can help you fix this machine if you get back to me.
gumdrop
Vendo 345-193
Sorry it took so long to reply.It is a 345 -193 vendo two deep.
gumdrop
vendo 345-193
sorry it took so long to reply.It is a vendo345-193 two deep machine
Motor sticking
gumdrop,
Thanks that helps a bunch. If it was working fine before, you didn't change anything and this just started then the first thing I would check for would be a sticky motor brake. There is a post here that covers this subject pretty well here: Motor keeps spinning
If you just got the machine, loaded it and it is vending 2 cans then none you might want to also check the Vendo manual (on pages 10 - 15 of the service section in that manual) for the correct setting for the form spacer, shims and cams for the product you are vending. The manual is located here: Vendo Quick Vend Parts and Service Manual Model 345
